Activity Forums Apple Final Cut Pro Legacy Fixing Interpolated Motion
  • Fixing Interpolated Motion
    Posted by Andrea Klipp on July 13, 2007 at 3:15 pm
    I am working on a project that has quite a few slo-motion, fast motion effects. at times playing in reverse. All are done in time ramping. What I am finding is that I am getting a lot of interpolated motion during the speed change. At times if I turn off frame blending, in some cases it makes it better – but not in all. Should frame blending be on or off??
    Shot speeds vary from 50% down to 30%, and as fast as 250%.
    The footage was shot DVCPro50 at 24p. We are working in Uncompressed 29.97.
    I don’t know if I should apply any other effects to smooth things out. Any suggestions for smoothing out these motions, would be very helpful.
    Andrea
    Ben Scott replied 19 years, 1 month ago 2 Members · 1 Reply
  • Ben Scott
    July 13, 2007 at 6:00 pm
    a really good idea is to send the clip to motion and then in timing parameters ask it to use optical flow
    it will take a while
    if long master clip it is coming from then may be idea to export and reimport into your timeline to only analyse that clip
    Check my podcast at https://cowcast.creativecow.net/final_cut_pro/index.html
    or my site at
    https://www.benscottarts.co.uk/ – – – – – – – – –
