Activity Forums Adobe After Effects fixing color
  • fixing color
    Posted by Angela Diamos on November 8, 2005 at 11:28 pm
    I shot my video with the night shot mistakenly on. Any suggestions for color correction? Everything is very washed out looking and has a greenish cast. All suggestions will be very appreciated, AD
    Also if I do convert the footage to B&W what is the best method.
    Chris Smith replied 20 years, 10 months ago 2 Members · 1 Reply
  • Chris Smith
    November 8, 2005 at 11:50 pm
    I would just convert to B&W. You can either add a hue/sat and pull all the saturation out then use a levels to adjust your luminance OR use Effects>Adjust>ChannelMixer and tick the monochrome function and blend the colors you have left.
    However since you probably only have color data in the green channel you might as well go with the hue/sat.
    Chris Smith
    https://www.sugarfilmproduction.com
