Activity › Forums › Apple Final Cut Pro Legacy › Fixing Bad Overexposure
Posted by Franco Noonan on December 18, 2009 at 12:30 pmHey guys,
I received this footage to cut together & at the beginning the footage is way overblown, almost to the point of bleeding out the entire image. It is an interview with half of the background being the sky, which doesn’t help.
Here is a still
https://i198.photobucket.com/albums/aa300/cashmeremedia/overesposed.jpg
Is there anyway I can fix this using FCP, i’ve tried multiple ways but can’t seem to do anything with it.
Any ideas?
Adam Mokrzecki replied 15 years, 1 month ago 10 Members · 9 Replies -
Walter Biscardi
December 18, 2009 at 1:20 pmIf the information is gone, then it’s gone.
The only way to know for sure is to take it into Color and bring down the highlights. If there’s anything left in the sky it will show up in Color.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Mark Raudonis
December 18, 2009 at 3:24 pmThat’s a case for the the “reshoot” plug in .
Not much else you can do with something that overexposed.
Mark
Arnie Schlissel
December 18, 2009 at 3:36 pmI think you are hosed. If you can reshoot, do so. If you can’t reshoot, cut around it. If you “need” the shot, well, sorry to hear that.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Shane Ross
December 18, 2009 at 5:07 pmWell…this might be somewhat salvageable. It is true that there is a lot of information lost, but some might be recoverable in some of the other color channels, such as green. And then you can try to map that to the other channels via a compositor like Shake or AE or there is a free plugin that deals with this, called CAPTAIN’S BLOWOUT FIXER:
https://pistolerapost.com/pluginz/index.html
Try that and see what you can salvage. it has helped me a few times.
But, this is a pretty bad shot…so don’t get your hopes up.
Shane
Read my blog, Little Frog in High Def -
Chris Borjis
December 18, 2009 at 5:31 pm[Franco Noonan] “Is there anyway I can fix this”
yeah, never hire that camera person again.
Jeremy Garchow
December 18, 2009 at 6:39 pm -
Kevin Monahan
December 18, 2009 at 9:58 pmGood idea. I’d use a gradient to simulate a sky.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Rick Desalvo
December 18, 2009 at 11:31 pmShort of a reshoot, I’d filter the image as suggested and then do a PIP with some B-Roll to redirect the viewer’s attention. Slight of hand may be your only choice here.
Adam Mokrzecki
July 12, 2011 at 3:29 pmI used this Tutorial, it did the trick for me.
https://monstersareart.blogspot.com/2009/06/overexposure-correction-in-final-cut.html
(3 years to get you an answer, but I just found this thread looking for a solution for the same problem, maybe it’ll help those looking for answer who find this thread the same way I did.)
