Activity Forums Adobe Premiere Pro fixing bad frames/dropped frames with a morphing technique?
  • fixing bad frames/dropped frames with a morphing technique?
    Posted by John Mayer on April 13, 2016 at 4:29 am
    I look for a simple solution to fix bad frames in clips that has dropped frames or tearing. I cut the bad frames manually, but I’m out of ideas how to make my workflow better. All I want is to create a morphed frame lets say B, between frames A and C (assuming that A is the frame before the dropped frame and C is the frame that resume the rest of the clip).
    Any ideas?
    thanks in advance
    John Mayer replied 10 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
