Activity Forums Adobe After Effects Fixing an After Efects Glitch
  • Fixing an After Efects Glitch
    Posted by Raymond Miller on October 5, 2011 at 8:08 pm
    Hello,
    I am working on an After Effects project, and I am using the Card Wipe transition effect to move between two sets of text.
    When the initial text spins as it should with the card wipe, the Back Layer has a glitch where the back layer will sporadically appear in the upper left corner of the composition before it appears in the position I want it too in the center if the composition.
    This has happened to me before but I improvised by covering it up with a mask. I don’t think that will work this time because the glitch is more apparent.
    How do I fix the glitch? Assuming there is a way.
    Thank you in advance.
    Oleg Pirogov replied 7 years, 7 months ago 5 Members · 4 Replies
  • Roland R. kahlenberg
    October 6, 2011 at 1:38 am
    This is very likely a memory-related issue.
    Try a hard reboot and then render just that specific time. If that works, then render the other timeline areas separately and compile them in AE or PP.
    If that doesn’t work then try reducing the number of cards.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia.
  • Christine Gonsalves
    January 9, 2019 at 5:32 pm
    I am having the same problem, were you able to find a fix?
    Thank you!
    Chrissy
  • Richard Garabedain
    January 10, 2019 at 7:18 pm
    could you just trim the back layer so that it does not start on the timeline until it actually shows up?
  • Oleg Pirogov
    January 11, 2019 at 12:07 am
    Saw this issue discussed on Adobe forum:
    Pre-compose the text layer before applying Card Dance. Effects like this are sensitive to dynamicalyl rasterized layers such as text since the effect itself neesds to sampel the entire layer and that doesn’t work correctly based on the text bounding box.
    Mylenium
    https://forums.adobe.com/thread/2313092
