Activity Forums Maxon Cinema 4D Fixing a Rotation Error that Makes an Object Spin 360 Degrees in the Opposite Direction to Reach the Next Keyframe
  • Fixing a Rotation Error that Makes an Object Spin 360 Degrees in the Opposite Direction to Reach the Next Keyframe
    Posted by Hayden Martin on September 25, 2014 at 11:05 pm
    Hi Guys
    I’ve attached my Project file
    8046_kr5.c4d.zip
    I’m having trouble when I change my project setting’s FPS to anything higher than 300. It becomes apparent that some of the robot’s axis rotations decide that they need to do a full 360 degree rotation to meet their next keyframe. As there will eventually be colliding objects in the scene, this is something I need to fix otherwise I’ll have stuff inexplicably flying everywhere once it is played in 30FPS
    I would really appreciate any amendments or suggestions
    Roman Volk replied 11 years, 2 months ago 2 Members · 1 Reply
  • Roman Volk
    July 15, 2015 at 6:07 pm
    I’m having the same issue with no solutions found anywhere. Right when I think, “oh, maybe the cinema 4d lite/after effects pipeline actually works well”, I turn on the motion blur… Not sure about bump edicate. Please answer if anyones solved this. I’ve tried highlighting the keyframes (that have been rotated an extra 360 degrees) in the timeline and lowering them manually, though when i input a -360 value in the “move” function, it seems to create a curve from the previous points that gradually rises to the final key frame, instead of simply subtracting them all by 360? and when im in the normal view an highlight the keyframes, i can’t find anywhere to change only one of the rotation values, instead of all of them. I’m kind of a cinema4d newbie though. Thanks for any assistance!
