Activity › Forums › Adobe Premiere Pro › Fixing a previously burned project
  • Fixing a previously burned project
    Posted by Rex Polanis on April 18, 2012 at 3:16 pm
    I Dynamincly linked a project from PPro(CS5.5) to Encor(5.1) and burned to dvd. Now there is a problem with the final video that I need to fix.
    Is it possible to make the corrections in PPro(5.5) dynamicly linked to the Encore(5.1) project and burn the disk again without remaking all the menus and chapter links extra in Encore. Basicly can I make the fix in ppro and reburn the project from encore?
    The reason I ask is because I tried this before but it seems once Encore creates a transcode file you have no other option but to start the project from sctrach. Why doesn’t encore retranscode the project?
    Thank you
    One man with courage makes a majority.
    Canon 7D
    Sony Vegas Pro 11
    Adobe CS5.5 Master Suite
    Jeff Pulera replied 14 years, 5 months ago 3 Members · 2 Replies
  • Chris Tompkins
    April 18, 2012 at 5:40 pm
    You probably could export the new edit from Premiere to AME, create the new DVD files.
    Then, launch the Encore project and relink the missing files to the new ones. Somehow.
    Chris Tompkins
    Video Atlanta LLC
  • Jeff Pulera
    April 19, 2012 at 1:23 pm
    Exactly what Chris said, have done this many times. Works best if you are NOT changing the duration at all, for instance correcting a title or some edit glitch. From Premiere, use AME to export an MPEG-2 for DVD file. I believe in Encore there is a Replace option, otherwise what I have done is to rename the original MPEG-2 to something different, then give the NEW file the name of the original (in same directory) to trick Encore into substituting the new file in your project.
    Since you used Dynamic Link, I know in the File menu in Encore there is a button to show the location of the encoded assets, so that should help you locate the trancoded files. I don’t use Dynamic Link, always export from AME because I like the manual control I get for situations such as these
    Jeff Pulera
    Safe Harbor Computers
