Activity Forums Apple Final Cut Pro Legacy Fix up Z1 damaged shots (auto-gain on)
  • Fix up Z1 damaged shots (auto-gain on)
    Posted by Ignatius Gorin on March 13, 2007 at 9:35 am
    A few weeks ago, some here helped me identify the problem I was having with tapes I received from a shooter from abroad (ITV’s for a short). The Z1 did was set to auto-gain (arghh…), which resulted in noise wherever lighting would drop.
    I had two extra ITV’s reshot to compensate, but I still need to use some of the “noisy” shots.
    My question is : what would you FCP-learned guys do with these noisy shots to try and make them usable?
    I could try and “stylize” all these shots with some kind of “heavy” filters, but although I’m trying to have it make sense in the script, I’m not sure it can…
    I can post a small uncompressed (or larger compressed) extract if needed.
    Many TIA’s.
    Ignatius Gorin replied 19 years, 6 months ago 3 Members · 3 Replies
  • David Roth weiss
    March 13, 2007 at 4:11 pm
    Make them B&W???
  • Peter Ralph
    March 13, 2007 at 11:47 pm
    adding some diffusion will help – gaussian blur if you don’t have anything else – there are a lot of plugins that do better –
    lowering the pedestal to crush the blacks is recommended if a lot of the noise is in the shadows
  • Ignatius Gorin
    March 16, 2007 at 8:56 am
    Thanks for that hint.
    I seem to remember running acros some kind of “denoiser” plugin somewhere in the past, although “denoiser” mostly applies to an audio effect, so I’m having a hard time finding it back. Any idea?
    TIA.
    PS : B&W is not an option here.
