Activity Forums Adobe After Effects fix to 7.0 problem for renderfarm macs
  • fix to 7.0 problem for renderfarm macs
    Posted by Carolyn Fusinato on February 27, 2006 at 11:48 pm
    If you’ve upgraded from 6.5 to 7.0 and you have a mac Renderfarm you may have noticed a bug in 7.0. If you pass a script using applescript to start the watch folder in After Effects as it states in the “After Effects Scripting Guide” on page 8 & the script causes After Effects to open, the watch folder won’t search. Similarly if you were to put the script in the “Scripts/Startup” folder in the Render Engine application folder, the same thing happens. But you can’t pass a script “open application” to After Effects first because you’ll get the error in After Effects: “After Effects error: sorry the last command could not be completed (-1700)”.
    Here are the scripts & the workaround:
    an After Effects Script file called watchfolder.jsx contains:
    var MyFolder = new Folder(““);
    app.watchFolder(MyFolder);
    an After Effects Script file called end.jsx contains:
    app.endWatchFolder();
    an Applescript saved as an application which I call “Start Renderfarm”:
    mount volume “
    set the_file to “/Applications/Adobe After Effects 7.0 RE/Scripts/watchfolder.jsx”
    set the_otherfile to “/Applications/Adobe After Effects 7.0 RE/Scripts/end.jsx”
    set the new_file to POSIX file the_file
    set the new_otherfile to POSIX file the_otherfile
    ignoring application responses
    tell application “Adobe After Effects 7.0”
    DoScript new_file
    end tell
    end ignoring
    delay 5
    DoScript new_otherfile with override
    DoScript new_file
    end tell
    end ignoring
    I have my renderfarm computers automatically login to the renderfarm account on start up & when they login the application “start renderfarm” is automatically opened to start the computer watching the networked watch folder.
    -Carolyn
    Carolyn Fusinato replied 20 years, 6 months ago 2 Members · 4 Replies
  • Carolyn Fusinato
    February 27, 2006 at 11:51 pm
    some stuff got editted out of my original post accdientily… it should say:
    var MyFolder = new Folder(“[your watch folder]”);
    mount volume “[your networked volume]”
    DoScript new_file
    end tell
    end ignoring
    delay 5
    DoScript new_file
    end tell
    end ignoring
  • Carolyn Fusinato
    February 28, 2006 at 12:08 am
    just an fyi,
    I manage fonts by using the user font folder on a renderfarm account that I create on each machine. I connect all renderfarm machines’ user folders by using a buch of afp internet location shortcuts like: afp://renderfarm1:password@IP.Address/renderfarm1 & then syncing the font folders. To get the fonts to load, log out of the account and log back in on the individual machine or just restart a monitorless renderfarm computer.
    We use two 500 Mhz G3s & a dual 1 gig G4 as permanent renderfarm machines and rotate any unused computers into the renderfarm when needed. Typically I’m using the two G3s & the G4, another dual 1 gig G4 and a dual 2Gig G5 to render on the renderfarm and I can take a project that would be a 45 minute render on my dual 2.5 Gig machine down to 5-6 minutes.
    To then convert the targa sequence to any other format takes another minute.
    Is it worth using a renderfarm to render?
    H*CK YA!
    -Carolyn
  • Jeff Petersen
    March 8, 2006 at 1:03 am
    Hi Carolyn,
    i have had lots of difficulty setting up renderfarms on my macs. i have a very similar group of computers that you have. i’m going to study your post a little more, but do you think you could offer me some setup tips if i give you some more details (network settings, AE settings, workflow tips). i’m basically sitting on an ethernet network with a Quad G5, 3Dual G4s, and my G4 powerbook so far, but i have had No success setting this up. And i really really want to! I own AE prod 7.
    thanks for any help,
    Jeff Petersen
    jpetersen@gccwired.com
  • Carolyn Fusinato
    March 10, 2006 at 12:35 am
    here’s another minor bug fix:
    When you install AE 7.0 RE on a mac & you also have a professional version installed — you may have problems calling up AE 7.0 RE in your applescript. This is because even though the application’s name in finder is “Adobe After Effects 7.0 RE” if you “get info” on it, the name of the file in “Name & Extension” is actually “Adobe After Effects 7.0.app”. Manually change it to “Adobe After Effects 7.0 RE.app” and your mac will now be able to differentiate between the Prof. & the Rend. Eng. versions.
    On computers that we rotate into the renderfarm when not in use we need to have both the Prof & the RE versions installed & that’s how I ran into this “gotcha”.
    -Carolyn
    http://www.fusinatodesign.com
