Activity › Forums › Apple Final Cut Pro › Fix or Anchor Videos into Background
  • Fix or Anchor Videos into Background
    Posted by Wannamake Amovie on November 6, 2012 at 11:57 am
    I’m trying to place a video to show up in the backgroud but i would like to still display animation in the foreground, similar to how in kanye west through the wire
    https://www.youtube.com/watch?v=uvb-1wjAtk4
    the videos are in polaroid frames.
    i know how to place them there, but as you can see in the video the camera moves and the videos stay in the place on the background. when I try doing that I have to move the video around in every frame and it looks pretty sloppy. is there a way to anchor the videos to the backgound?
    Wannamake Amovie replied 13 years, 9 months ago 2 Members · 4 Replies
  • John Fishback
    November 6, 2012 at 9:19 pm
    You need to track the background to hold the videos in place. That can be done on Motion or AfterFX.
    John
    MacPro 8-core 2.8GHz, 8 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.5
    Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Wannamake Amovie
    November 7, 2012 at 1:49 pm
    it is not possible in final cut pro?
  • John Fishback
    November 7, 2012 at 3:28 pm
    AFAIK, FCPX does not have tracking at the moment. You have to do it with keyframes which as you’ve discovered is not easy and almost impossible when you want a solid lock.
    John
    FCP-X 10.0.6
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Wannamake Amovie
    December 8, 2012 at 4:00 pm
    that’s really too bad, i guess i’ll have to try out something else then.
    thanks a lot for all the helpful information.
