Activity Forums Adobe After Effects Fix CC Light Rays in 3d space?
  • Fix CC Light Rays in 3d space?
    Posted by Dean Pickersgill on January 16, 2014 at 2:41 pm
    Searched everywhere to find out how to fix the origin point of a CC Light Ray effect in 3d space – can anyone give me a hint please?
    I want to fix the effect in my 3d space so that the origin-point moves relative to the camera. At the moment I’m putting it onto an adjustment layer, but I find when I move the camera the effect doesn’t move as I expect.
    Advice anyone please?
    Rgds Dean
    Jj Foote replied 9 years, 7 months ago 3 Members · 3 Replies
  • Darby Edelen
    January 16, 2014 at 2:58 pm
    That requires a little bit of expression pixie dust. First make sure that your Light Rays layer is a 2D layer. Then if you create a 3D Null you can tie the 2D effect’s Center property to it with an expression like this:
    l = thisComp.layer("Null 1");
    l.toComp(l.anchorPoint);
    The first line creates a variable ‘l’ and assigns it the 3D Null layer object. The second line converts the 3D Null layer’s anchor point into a point in composition space (a 2D screen coordinate).
    If the layer you’re applying Light Rays to is not composition sized you can enclose the 2nd line in a fromComp() function call like so:
    fromComp(l.toComp(l.anchorPoint));
    Generally I recommend that you use a composition sized layer for such an effect though.
    You can alt-click on the property’s stop watch to add an expression or press alt-shift-= with the property selected (alt is the option key on Mac). In this case you’d apply the expression to the ‘Center’ property of CC Light Rays.
    Darby Edelen
  • Dean Pickersgill
    January 16, 2014 at 3:26 pm
    Fab Darby, thanks for sharing, exactly what I needed 🙂
    Rgds Dean
  • Jj Foote
    February 12, 2017 at 12:37 am
    l = thisComp.layer(“Null 1”);
    This didn’t work
    Any other ideas?
