Activity Forums Maxon Cinema 4D Fix “blocky” ribbon using sweep nurbs?
  • Fix “blocky” ribbon using sweep nurbs?
    Posted by Chris Powers on December 2, 2015 at 3:53 pm
    Hi guys,
    So, I am incredibly new to C4D, I’ve only gained access to it via my recent upgrade to Adobe CC 2015 (so, I only have the bundled C4D lite). Here is my question:
    I’m trying to make a ribbon animation using “sweep” to sweep a rectangle shape a long a spline that I drew (following this tutorial, starting at 3:50. https://greyscalegorilla.com/tutorials/how-to-make-a-ribbon-wall-graphic-in-cinema-4d/ )
    The problem is that around some corners, the ribbon is very polygonal and blocky. I’m assuming there’s a way to up the repetition of rectangles or something like that in order to smooth this out, but I’m not sure where I could find it…?
    Adam Trachtenberg replied 10 years, 9 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    December 2, 2015 at 9:32 pm
    You probably need to adjust the path spline’s type or subdivisions. Setting the type to “subdivided will tell you if that’s the issue. If that fixes it you might want to experiment with other settings to get the polygon count down.
