Activity Forums VEGAS Pro Fitting slideshow images to music
  • Fitting slideshow images to music
    Posted by Diego Solis on September 9, 2009 at 12:33 am
    Hi, I use SV Pro 10 and couldn’t find a related thread here, so here’s the question:
    I’m preparing a slide show with 35 photos and a 6-minute piece of music. I want to fit the images to the music, but I don’t know how to pull/push all track images TOGETHER to fit them without having to do it one by one. Is there a way?
    Thanks in advance.
    Mike Kujbida replied 17 years ago 2 Members · 3 Replies
  • Mike Kujbida
    September 9, 2009 at 11:07 am
    35 images for 6 minutes is just a bit over 10 sec./image.
    Options – Prefs – Editing and set the still image length to 10 sec.
    Drop all 35 on the timeline in the correct order.
    Click image #1, Shift+Click the last one and press the ‘G’ key to Group them together.
    Place your cursor at the end of the last image, hold down the Ctrl key (you’ll now see a ~ symbol under it) and drag the entire sequence out to the desired length.
  • Diego Solis
    September 10, 2009 at 12:07 am
    Thank you, I did everything except for step 1 although for some reason the grouping didn’t work for me. I’ll use your process and see how it goes, thks. again.
  • Mike Kujbida
    September 10, 2009 at 12:21 am
    I create a lot of slide shows and use this technique a lot so hopefully it’ll work for you too.
