Activity › Forums › Adobe After Effects Expressions › Fitting sentence text within a pre-established box (splitting lines)
  • Fitting sentence text within a pre-established box (splitting lines)
    Posted by Matthew Ingram on November 2, 2024 at 2:30 pm
    Hi there,
    I’ve had a good look around – I can find lots of tutorials which create a box around pre-established text. But none the other way around 😭
    With this, I could have a set sized box and then fill it with text (actually coming in from a CSV) and have the lines automatically split.
    This would be such a great help.
    Thank you.
    Yoan Boisjoli replied 1 year, 11 months ago 2 Members · 6 Replies
  • Yoan Boisjoli
    November 2, 2024 at 2:36 pm
    Here’s a helpful tutorial:
    https://youtu.be/-n0RKDlbGas?si=abArBOJvLzdZy0NZ
    Is this what you’re aiming for?
  • Yoan Boisjoli
    November 2, 2024 at 2:38 pm
    There’s also this tutorial where it’s well explained:
    https://youtu.be/flnRYVMbMmQ?si=Ejxt5r98d4XQY7wb
  • Matthew Ingram
    November 2, 2024 at 2:47 pm
    Thank you very much, Yoan. But this doesn’t quite do what I need to.
    To explain myself better – in Illustrator (see attached images) when you create text within a box it automatically splits the lines.
    Is there any way of doing that?
  • Yoan Boisjoli
    November 2, 2024 at 2:51 pm
    Hi Matthew! Are you talking about a paragraph text box?
    In after effects if you simply drag a square with the text tool you can make a paragraph text box.
    Let me know if this is what you are referring to.
    Cheers.
  • Matthew Ingram
    OK, I’ve achieved this by splitting the lines in the CSV document. Would still be curious! Thank you again.
  • Yoan Boisjoli
    November 2, 2024 at 3:03 pm
    If you set up a paragraph text box in After Effects, you can use an expression on sourceText to pull in text from your CSV and it’ll split the lines automatically to fit within the box. Something like this:
    txt = footage("yourCSVfile.csv").dataValue([0, 0]); // Change this to point to your CSV file and correct cell
    txt;
