Activity Forums Adobe Premiere Pro Fitting photos to width or height
  • Fitting photos to width or height
    Posted by Dave Middleton on May 4, 2010 at 11:32 am
    Is there a quick way to allow an imported image to fit to either the width or height of the composition ?
    It’s a pain having to scale an image down manually and play around so a particular edge is just right.
    I know there is the scale to frame option but what I’m after for e.g is importing a very wide image to do a pan on and getting PP to fit the height correctly.
    Thanks, Dave.
    Dave Middleton replied 16 years, 4 months ago 3 Members · 3 Replies
  • Eric Monroe
    May 4, 2010 at 5:26 pm
    Try this:
    Go into the Effects tab then Video Effects>Distort>Transform
    the transform effect allows you to have individual control over a still image or video’s height and/or width.
    Hope that helps…..fastest way i know to do it.
  • Alan Lloyd
    May 4, 2010 at 5:44 pm
    If you’re maintaining the aspect ratio, effects>motion>scale will work. If you highlight the “motion” setting, you’ll see a bounding box around the image as you scale it. Just drag the slider until the vertical fits and you’re there.
  • Dave Middleton
    May 5, 2010 at 7:32 am
    Thanks Guys, I’ll give it a try.
    Dave.
