Activity Forums Adobe Premiere Pro Fit video file into a shape using Premiere Pro
  • Fit video file into a shape using Premiere Pro
    Posted by Kim Guthrie on February 15, 2012 at 8:25 pm
    How do I fit a video into a shape using only Premiere Pro? Just like Photoshop uses a clipping mask to clip images into the shape of another image, I want to clip a video clip inside a circle shape. I have been trying everything I can think of since 8 AM and have had no success finding help on-line. IS it even possible?
    Timi Boose replied 12 years, 6 months ago 5 Members · 6 Replies
  • Ann Bens
    February 15, 2012 at 8:31 pm
    Draw a white circle in the Title and superimpose over the clip
    Add a Fast Blur for feather if needed.
    Add Track Matte Effect and set it to track two.
    You can also use the Circle effect with several properties build in.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Scott Roberts
    February 16, 2012 at 8:46 am
  • Ann Bens
    February 16, 2012 at 1:56 pm
    Bit tricky setting a garbage matte to a circle.
  • Scott Roberts
    February 19, 2012 at 4:05 am
    Ah, good point. I missed that part – only seeing the beginning of the post which said “shape”.
    LittleBlackBird.net
    My Blog
  • Micah Debenedetto
    January 27, 2013 at 10:44 pm
    what about green screen footage with keyed out background. I want the footage behind it to show only within the silhouette of remaining footage? like at 2:03 seconds into this video. https://youtu.be/O3WRXYYBwRA?t=2m3s
  • Timi Boose
    March 1, 2014 at 12:12 am
    I’m trying to do this exact same thing.
    What do you mean by “draw a circle in the Title”?
    I’ve tried Generate circle and it makes a cutout circle for the video but I can’t figure out how to make it so the video is in a circle and it is superimposed over another video. I just see the video in the circle and it’s a solid color around the sides.
    After that, I’m hoping to be able to move it around to music. i know how to do some of this in AfterEffects but it’s too hard to do anything to music in that program.
