Activity Forums Apple Final Cut Pro Legacy “fit to fill” for multi images
  • “fit to fill” for multi images
    Posted by Tammy05 on September 24, 2005 at 1:08 am
    I have multiple still images that I would like to “fit to fill” to a section of music. Can I do this without manually changing the time for each image? If so, how do you do this?
    Tam
    Tammy05 replied 21 years ago 2 Members · 2 Replies
  • Kevin Monahan
    September 24, 2005 at 7:59 pm
    You might want to use iPhoto 5 for this. FCP won’t do this automatically. iPhoto, however, will do that and output a quicktime which you can drop into FCP. Otherwise, you have to do this by hand – dividing the duration of the song by the amount of stills. Fit to Fill won’t work for you in this way because it’s only for one clip at a time, not multiple stills.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Tammy05
    September 24, 2005 at 8:55 pm
    Thanks so much for the reply. I was afraid of that. I appreciate the response to my question.
    Tam
