Activity Forums Adobe Encore DVD Fit to disc?
  • Fit to disc?
    Posted by Point&shoot on November 2, 2005 at 6:07 pm
    I have a timeline in premiere that is about 1:45. When i enecoded to mpeg2 for DVD, i used the presets. Import into Encore and it’s too big to fit on disc. It came out to about 6 gigs. (I cant remeber exactly) Another porgram that I have used, MyDVD allows you to sort of “fit to disc” by changing a setting from high quality(1 hr length) to standard play (2 hr length). Does Encore have anything like this? Thanks
    Hector Melendez replied 20 years, 10 months ago 3 Members · 2 Replies
  • Joe Bowden
    November 2, 2005 at 10:58 pm
    Export to AVI instead of MPEG-2, then import that into Encore, which will then fit it to disc.
  • Hector Melendez
    November 3, 2005 at 3:03 am
    Click the imported file (A/V) and set transcoding settings to automatic. Encore will do the rest.
    File>transcoding>transcoding settings>automatic. Also expanding the project window you can set this to automatic.
