Activity › Forums › Adobe After Effects Expressions › Fit to Comp Width
Fit to Comp Width
Posted by Borko Grujic on March 5, 2013 at 10:10 amHi,
How do I call “Fit to Comp Width” on a layer from a script
I got all other stuff taken care of, I need a function name, I could not find any references for this.
BTimur Solomon replied 4 years, 4 months ago 4 Members · 7 Replies -
Dan Ebberts
March 5, 2013 at 7:16 pmAssuming your layer is selected and your comp has focus, this should work:
app.executeCommand(app.findMenuCommandId(“Fit to Comp Width”));
Or, you could do it this way:
var myComp = app.project.activeItem;
var myLayer = myComp.layer(1);
var s = (myComp.width*myComp.pixelAspect)/(myLayer.width*myLayer.source.pixelAspect)*100;
myLayer.property(“Scale”).setValue([s,s]);Dan
John Gate
August 17, 2021 at 5:36 pmHi Dan,
Can you please provide similar code for “Fit to Comp” ?
Dan Ebberts
August 17, 2021 at 7:22 pmI guess that would be like this:
var s = myLayer.property("Scale").value;
var x = (myComp.width*myComp.pixelAspect)/(myLayer.width*myLayer.source.pixelAspect);
var y = myComp.height/myLayer.height;
myLayer.property("Scale").setValue([s[0]*x,s[1]*y]);
Or an expression like this:
x = (thisComp.width*thisComp.pixelAspect)/(width*thisLayer.source.pixelAspect);
y = thisComp.height/height;
[value[0]*x,value[1]*y]
John Gate
August 18, 2021 at 10:16 amThank you very much, and especially for replying even after so many years to this post
Timur Solomon
May 11, 2022 at 5:09 pmHi Dan,
Thanks for the expression.
The question is, is it possible to do the same for text? it doesn’t have a source parameter and the expression doesn’t work
Dan Ebberts
May 11, 2022 at 5:25 pmI guess it depends on what you’re after exactly. If you just want to scale the text so that its width matches the comp width, a scale expression like this should work:
s = (thisComp.width/sourceRectAtTime(time,false).width)*100;
[s,s]
