Activity › Forums › Maxon Cinema 4D › Fisheye wide angle spherical distortion issues
  • Fisheye wide angle spherical distortion issues
    Posted by Olly Bea on October 25, 2008 at 9:12 am
    Hi all
    I have followed both the fisheye and wide and distortion threads on this forum but I am confused as to how to create a fisheye lens effect.
    Can anyone shed some light on it?
    I have tried to drop a transparent material (with 1.5 refractive index) onto the camera but it does very little. I guess I am making some fundamental mistake. Any ideas? Also can you explain what is meant by Adam’s comment “You’ll have to use Best AA because the transparent material kills Object AA. ” It has confused me no end.
    You’ll probably guess I am relatively new to all this!
    Many thanks for your help
    Olly
    Gon Perdigao replied 17 years, 8 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    October 25, 2008 at 1:28 pm
    Sorry I confused you. 🙂
    First, you can’t just put a transparent material on a camera to achieve the effect. You have to actually model lens, place the material on the lens, and then have the camera look through the lens in order to achieve the effect.
    Now, you may have noticed that the default “Geometry” anti-aliasing does not work through transparency. Geometry AA attempts to speed up rendering by only effecting object edges. Notice that it also does not smooth textures?
    So naturally if your whole scene is being viewed through a transparent material, you will not have any anti-aliasing with Geometry AA. In contrast, “Best” anti-aliasing applies AA to the entire frame regardless of transparency or other effects.
  • Olly Bea
    October 25, 2008 at 3:38 pm
    Not a problem, I am easily confused!
    I’ll try these out, thanks for your help.
    Olly
  • Gon Perdigao
    January 6, 2009 at 5:55 pm
    well you have this plug in that might help you https://wfcam4d.multimeios.pt i hope that helps
