Activity › Forums › Apple Final Cut Pro Legacy › Fisheye effect removal/correction?
Posted by Arturo Glass on August 6, 2010 at 6:40 amDoes anyone know of a plug-in or way of removing, or at least reducing, the distortion created by a fisheye lens? I’m using FCP 7.0.2.
Mark Suszko replied 10 years, 8 months ago 4 Members · 6 Replies -
Andy Mees
August 6, 2010 at 7:59 amTry giving it a “poke” (Video Filters > Distort > Poke) … but I’m guessing it won’t be too pretty even with some correction
Best
Andy -
Mark Suszko
August 6, 2010 at 1:01 pmMap it to a 3-d hemisphere, in AE or in a 3D CGI animation program?
Mark Suszko
August 6, 2010 at 1:43 pmIn AE I think you do this with camera projection. How you generate the concave disk, I dunno, I’m not an AE guy. I could do it in Lightwave, I think, just projecting the video onto a properly shaped hemispheric concave solid.
Arturo Glass
August 6, 2010 at 10:12 pmThanks for the suggestions. After fooling around with FCP a bit I figured out one of the fisheye effect plugins I have allows you to adjust the fisheye effect radius and allows for negative curvature. It looks pretty good.
Edward Bally
January 8, 2016 at 6:56 pmHello! Can you tell which plug ins you used for the removal of the fish eye effect on FCP7? That would help me a lot!!
Mark Suszko
January 9, 2016 at 1:09 amSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
