Activity › Forums › Adobe After Effects › Fisheye camera settings
  • Kevin Camp
    February 23, 2007 at 9:03 pm
    the cc lens effect will create distortion similar to what you’d see with a fisheye lens, if you want to just distort existing footage or a comp.
    i would think that creating a 3d cam with a wide angle (15mm or less) should create a fairly good fisheye like lens look if you have created a 3d scene in ae.
  • David Bogie
    February 23, 2007 at 10:58 pm
    Yar, but AE’s camera has no barrel distortion. You would need to process the view form the camera after it’s been grabbed. There might be a way to nest the camera output into a downstream comp. Never seen it done but there was talk earlier of doing “live on-stage cameras to projection monitors.”
    bogiesan
  • Eddie Torre
    February 24, 2007 at 4:04 am
    Also, Pete’s Plugins>Fisheye
    https://www.petewarden.com/
