Activity Forums Adobe Premiere Pro firwire for sony hdv (player/recorder) 1080i
  • firwire for sony hdv (player/recorder) 1080i
    Posted by Ayman Abdel-basset on June 2, 2005 at 9:21 am
    hi
    i’d like to know which firewires are compatible with sony hdv1080i(palyer/recorder)..
    to capture and recored using premire pro1.5.
    thanx
    Ayman
    Tim Kolb replied 21 years, 3 months ago 3 Members · 2 Replies
  • Mitchell Lopez
    June 2, 2005 at 3:45 pm
    I’m not really sure what the issue is. But any OHCI compliant firewire card should work. 400Mbps whould work (you do not need faster)
  • Tim Kolb
    June 2, 2005 at 3:46 pm
    First, you’ll need to upgrade to v1.5.1 (free) from the Adobe website for HDV support.
    Then…any properly operating FireWire port should work as long as you have harddrives that will keep up…(fast DV capable harddrives should be fine…though the file conversion may take a bit to catch up after you stop capturing…that’s normal)
    TimK
    Kolb Syverson Communications
    Creative Cow Host
    2004, 2005 NAB Post Production Conference Premiere Pro Technical Chair
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
