Activity › Forums › Adobe Premiere Pro › First Two Frames Wrong After Rendering
Sam Crutsinger replied 10 years, 1 month ago 6 Members · 16 Replies
Rob Wood
December 16, 2012 at 4:07 amProgress! I think!
I changed the Sequence Settings for Preview File Format to “Quicktime (Desktop)”, and it seems to have fixed the issue:
https://screencast.com/t/yHhQQWPscdLKDoes this make any sense?
Tom Daigon
December 16, 2012 at 4:56 amWell congrats.
I would need to know all the data on the Quicktime Desktop codec you changed to, to even start figuring out what happened.
I saw that its the Animation codec but I dont know its franes rate or whether its Progressive or interlaces.Non drop or drop frame. Stuff like that.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Dennis Radeke
December 16, 2012 at 5:29 pmClean your media cache in prefs and delete all renders in the project(?) menu. Sorry, on an iPad at the moment…
Dennis
Tom Daigon
December 16, 2012 at 8:30 pmAnd if you are on a Mac, wonky things can sometimes be addressed by Trashing Preferences and Repairing Permission (I use Onyx for this).
Tom Daigon
HP Z820 Dual 2687
64GB ram
Jarle Leirpoll
March 30, 2013 at 9:46 amThis is what happens if you have sequence settings that differ from the source settings. If you have 24p footage in a 29.97 sequence, Premiere needs to duplicate some frames. When you’ve rendered the sequence, the problem will show.
This happens in two scenarios.
1. You’ve manually chosen the wrong frame rate when making the sequence
2. Your Premiere Pro installation is not properly activated, and you’re missing a lot of sequence settings. When you make a new sequence automatically in Premiere (or let Premiere choose settings) the right settings are not available, and Premiere uses one of the other ones.See https://helpx.adobe.com/premiere-pro/kb/features-presets-missing-premiere-pro.html for a solution to the problem.
Jarle Leirpoll
PremierePro.net -
Sam Crutsinger
August 4, 2016 at 6:19 pm
