Activity Forums Blackmagic Design First HD project – Need lots of help
  • First HD project – Need lots of help
    Posted by Anthony Vamvakitis on September 19, 2006 at 9:26 pm
    Doing an HD project for the first time and need help with settings.
    First, my setup – G5 Quad with multibridge extreme, monitoring on Aquos LCD via HDMI.
    The tapes they are shooting on are DVCPro50.
    I was told to set my sequence up at 1080i @ 59.94. I see those settings but I also see ones that say ‘DVC PRO 1080i 60’ and then ones that say ‘8 Bit’ (i’m using the 8 bit right now).
    What are the differences – is one more compressed than the other?
    Also, and even more importantly, I’m having trouble monitoring. What do my settings need to be in Blackmagic System preferences to view on the monitor?
    Anthony Vamvakitis replied 20 years ago 3 Members · 5 Replies
  • Aaron Neitz
    September 19, 2006 at 9:34 pm
    DVCPRO-50 is NTSC or PAL. Not HD.
  • Anthony Vamvakitis
    September 20, 2006 at 6:45 pm
    Thanks. Any help on the 2nd part –
    … and, in decklink settings, does hdtv up/down converter pull down menu options have any effect when I’m monitoring?
    September 20, 2006 at 6:46 pm
  • Kristian Lam
    September 21, 2006 at 7:53 am
    [Anthony Vamvakitis] “Also, and even more importantly, I’m having trouble monitoring. What do my settings need to be in Blackmagic System preferences to view on the monitor?”
    You need to configure your porject using our easy setups. Make sure your View > Video Display option matches the timeline. DVCPRO HD clips will use the 8-bit video display options.
    [Anthony Vamvakitis] “… and, in decklink settings, does hdtv up/down converter pull down menu options have any effect when I’m monitoring?”
    Yes the settings will affect your monitoring. They will turn on down conversion which means you’ll be monitoring in SD instead of HD.
    regards
    Kristian Lam
    Blackmagic Design
    September 21, 2006 at 11:26 pm
    thanks, kristian
