Activity Forums Apple Final Cut Pro Legacy First HD Clip Basic Question
  • First HD Clip Basic Question
    Posted by Michael Allen on May 3, 2006 at 11:19 pm
    Captured my first DVCProHd footage today(Using FCP5 and a kona LH). No problems at all with the capture. Here is my question. I can play the clips from my bin in the viewer and they pass right through to the monitor. However, when I place a clip in the timeline it will play in the canvas window but will not pass through to the monitor. The image on the monitor is frozen (all clips in the timeline have been rendered).
    Also, as soon as I placed the clip in the timeline, I got a red line above indicating a needs render. Is this correct, or do I have a setup problem.
    Jerry Hofmann replied 20 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 3, 2006 at 11:48 pm
    You have a setup problem. Shouldn’t have to render… create a new sequence whose settings are set to the DVCPROHD using the frame rate etc. you captured with.
    Jerry
