Activity Forums Panasonic Cameras First film with dvx-100
  • First film with dvx-100
    Posted by Maxime Michaud on October 12, 2009 at 4:46 am
    Hello, I make a short film with a DVX-100.
    I shot in 24p standard.
    As editing software, I Premiere CS4 and Vegas 9.
    I know the best properties to transfer my video camera to my computer ?
    I know the best properties to complete my project.
    Model ? Ntsc 24p ?
    -field order ? None (progressive analysis ?)
    Frequency image ? 23,976 film ivtc ?
    -type fuzzy ? Gaussian ?
    -mode deinterlacing ? Merge fields ?
    Bar timing ? (lossy smpte ? 29,97 fps)
    Then, It is possible to convert this video HD PAR more ?
    How to get the best possible quality ?
    If I add an effect Magic Bullet, The image has a small earthquake, It is not stable, Is this normal ?
    Brief, I have advice.
    Thank you
    Maxime Michaud replied 16 years, 10 months ago 1 Member · 6 Replies
  • Maxime Michaud
    October 14, 2009 at 2:51 am
    Model ? Ntsc 24p ?
    Thank you
  • Maxime Michaud
    October 14, 2009 at 11:19 pm
    ok thanks, if I have any problems, i’ll ask you !
  • Maxime Michaud
    October 19, 2009 at 2:39 am
    I would just like to know the best way to import my video.
    How do I capture to my computer ?
    I guess that i’m making mistakes and it’s why it does not work when I add effects on my video.
  • Maxime Michaud
    October 22, 2009 at 3:15 am
    I do not understand… Really sorry.
    What do I have to do ? First, I import with what ?
    I have vegas and premiere. Or is there any good software to import from the camera ? I shooted in 24p standard.
    You are saying that I have to delete the 3:2 pulldown ? What is this ? I don’t see any instructions with my softwares ? I can only choose if I import in 29… or 24…
    And after at the montage ?… ?
    Well, I just need clear help, a guideline to start.
  • Maxime Michaud
    October 22, 2009 at 3:28 pm
    this is more clear for me, thank you. i’ll ask other informations in the vegas or premiere forum. thanks
  • Maxime Michaud
    November 3, 2009 at 1:07 am
    My problem is still not resolved…
    I only found instructions about removing 3:2 pulldown for Adobe After Effects, which I do not have…nobody is answering my questions… if i knew i’d shot in 24p advanced, or just in 30p…
