Activity Forums VEGAS Pro First cropping then resizing
  • First cropping then resizing
    Posted by Mette Skagen on June 15, 2011 at 8:26 am
    I’ve seen a lot of posts about how to crop and resize clips in Vegas, most seem to not understand the inverted pan/crop technique. I do understand it, at least I think I do, but i don’t understand how i can both crop and resize a clip at the same time.
    What i want to do is to do is to crop and use only the center of one clip that I have. I then want to resize this cropped part of the clip and use it as a Video Overlay clip above another clip only in the upper-right corner.
    Do you guys understand the question and can this be done?
    Jaime Uribelarrea replied 12 years, 3 months ago 3 Members · 5 Replies
  • Danny Hays
    June 15, 2011 at 7:49 pm
    Use the event pan and crop to crop the clip, with Maintain aspect ratio checked. (Default) Then use the track motion to resise and position where you want.
  • Mette Skagen
    June 16, 2011 at 7:59 pm
    There we go, i thought there would have to be two different tools!
  • Danny Hays
    June 17, 2011 at 3:33 am
    MOOOO! ,, you now,, the cow thing,, ;^)
  • Jaime Uribelarrea
    May 31, 2014 at 8:18 am
    Hi, similar problem here, I’m starting to feel a little bit slow in the head.
    I have some 2x anamorphic footage originally shot at 1920×1080.
    I need to stretch horizontally until 3840×1080, and then crop the sides down to 2580×1080 to achieve a 2.39:1 aspect ratio.
    I simply cannot find a way to do this without stretching, rendering, importing, and then cropping.
    Can I do this with just 1 source 1920×1080 file?
  • Jaime Uribelarrea
    May 31, 2014 at 8:55 am
    Oh, wait, I think I found a solution by guesstimating some numbers (I don’t even know how I thought of those calculations).
    If I take 1920×1080 footage that was shot with 2x anamorphic lens attached, put it in a 1920×1080 project, and then use these pan/crop settings, I get the result I want: a 2.39:1 frame of video within within a 1920×1080 project.
    The settings are:
    Width: 1290
    Height: 1460
    Maintain A.R.: NO
    Stretch to fill: YES
    Left is original 1920×1080 squeezed footage. Right is stretched, cropped, and resized (height) result, all with one pan/crop setting.
    The numbers might be a bit off because I just let the math run wild in my head:
    2580 [2.39x 1080] / 3840 [2x 1920] = 0.671875
    1920 [project width] x 0.671875 = 1290
    1.777 [proj. A.R.] / 2.39 [desired A.R.] = 0.74
    1080 [proj. height] / 0.74 [???] = 1459 ~ 1460
