Activity Forums Maxon Cinema 4D First Build. Hardware advice needed please!
  • First Build. Hardware advice needed please!
    Posted by Peter Chicarielli on April 7, 2015 at 1:15 am
    Hello all! Thank you in advance for taking the time to check this out for me. I’ve never built a PC before, so I’m sure all of you can understand and recall the feelings/thoughts I’m going through.
    A general 3d/graphic design build.
    I understand more cores equal faster render times and less but more powerful cores allow for a faster live interaction when modeling.
    There is a possibility I will use third party software to utilize my GPU because Cinema 4d does not use GPU for render.
    It would be great to have a 12-core, or two 6-core CPU’s but my budget was $1500.
    Everything on this list, including insurance and subtracting mail in rebates, comes to $1546. After all the research I’ve done, I don’t mind spending the extra 46 bucks!
    PC Build Below: Let me know if I’m missing anything or you guys see any red flags on this build! Thanks!!!
    CPU: i7-5820k
    https://www.microcent…_Tray_Processor
    MOBO: ASRock X99 Extreme4 LGA 2011-3 ATX Intel Motherboard
    https://www.microcent…tel_Motherboard
    RAM: Crucial Ballistix Sport 16GB Kit (8GBx2) DDR4
    https://www.amazon.co…d=ATVPDKIKX0DER
    GPU: Gigabyte GeForce GTX 970
    PSU: CORSAIR CX series CX750 750W ATX12V
    https://www.newegg.co…N82E16817139040
    Storage: Crucial BX100 120GB SATA III 6Gb/s 2.5″ Solid State | Seagate Barracuda 2TB 7,200 RPM SATA III 6Gb/s 3.5
    SSD: https://www.microcent…_CT120BX100SSD1
    HDD: https://www.microcent…ive_STBD2000101
    Case: Cooler Master HAF 912 Mid Tower ATX Computer Case
    https://www.microcent…X_Computer_Case
    Liquid Cooler: CORSAIR Hydro Series H105 Extreme Performance 240mm Liquid CPU Cooler
    https://www.newegg.co…N82E16835181060
    Optical Drive: WH14NS40 16x Internal Blu-Ray Rewriter
    https://www.microcent…lu-Ray_Rewriter
    OS: Windows 7
    https://www.microcent…t_English_-_OEM
    Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound 3.5g:
    https://www.microcent…al_Compound_35g
    Peter Chicarielli replied 11 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
