Activity › Forums › VEGAS Pro › First blu-ray authoring attempt.
  • First blu-ray authoring attempt.
    Posted by Tim Maddoux on April 7, 2014 at 8:27 pm
    Greetings All!
    After creating my first blu-ray in DVDA, I tested it in a sony blu-ray player and had an interesting result.
    After playing the intro media the player went back to its beginning default state like I had press the stop button. It never moved past the intro media to the menu selections.
    I can’t see reasons why this is happening.
    Any help is greatly appreciated
    Tim Maddoux replied 12 years, 5 months ago 2 Members · 2 Replies
  • Chris Hewitt
    April 8, 2014 at 2:14 pm
    Hi Tim, I think I can help you with that problem.
    For the ‘First Play settings, the End Action should read ‘Menu-Start’. The same applies for the Remote Control settings or the disc won’t play past the First Start file, especially for BluRay although the same applies for DVD.
    I did have this problem and took me a while to find a solution but the above did work for me and no problems since.
    Hope this helps.
  • Tim Maddoux
    April 9, 2014 at 2:41 am
    Thank you so much Chris! That was it.
    Appreciate you man!
