Activity Forums VEGAS Pro First Attempt At Movie. Worked fine but file size is WAY too big.
  • First Attempt At Movie. Worked fine but file size is WAY too big.
    Posted by Lee Chumacas on January 9, 2009 at 5:20 am
    Hi there.
    I used a combination of Windows Movie Maker and Sony Vegas to produce a short original music video. The song/movie is only around 4:30 but the file size (after being rendered) is almost 1 Gig. Even after RARing it’s still 379 MB. The audio plays fine, and all of the clips/effects/transitions I added work perfectly, it will just be impossible to upload to the web at this size? There has to be a way to fix this. My friend said something about using a different codec, but I don’t know much about them. Any help would be much appreciated. Thanks in advance!
    Sue Rooney replied 15 years, 1 month ago 3 Members · 2 Replies
  • John Rofrano
    January 9, 2009 at 3:28 pm
    Your friend is correct. Try using the Sony AVC or Main Concept AVC as the render type. These should give you smaller filesize and web compatibility.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Sue Rooney
    August 10, 2011 at 2:02 pm
    I read your post on a web site my maiden name is Chumacas as you know its not a very common name are we related?
    Sue
