Activity › Forums › Adobe After Effects › first 1920 X 1080 comp
  • first 1920 X 1080 comp
    Posted by Mark Wilkinson on February 9, 2007 at 1:58 am
    i am working on a project building some graphics from scratch and they have explained that the piece is HD and that it is 1920 X 1080. if i am going to set up a new comp in AE do i just do it at those dimensions with the pixel aspect ratio at D1/DV NTSC (0.9) ? thanks
    Mark Wilkinson replied 19 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Andrew Kramer
    February 9, 2007 at 2:36 am
    HD is usually Square pixels.
    Andrew
  • Mark Wilkinson
    February 9, 2007 at 5:42 am
    so i set up a sequence in FCP. a preset that is 1440 X 1080. i then rendered out a slug and brought it into AE. i dragged it to the “new comp” icon and it gave me a comp that is 1920 X 1080 with an aspect ratio that is “Non-square (1.33:1)” and a frame rate of 25 FPS.
  • Brian Mulligan
    February 9, 2007 at 2:14 pm
    Why not try a 1920×1080 preset? It should give you a comp size of 1920×1080 with 1:1 pixels (square)
    BKM
  • Steve Roberts
    February 9, 2007 at 3:58 pm
    Yep, 1920×1080 is 16×9 square pixels:
    1920/16 = 120
    1080/9 = 120
    Since we have a common factor for height and width at 16×9, we’re talking square pixels here. 🙂 So use the 1920×1080 square pixel preset.
  • Marco Salsiccia
    February 9, 2007 at 7:54 pm
    Watch the Aspect Ratio when you create the 1440×1080 composition. It’s going to stretch your pixels to the non-square 1.33 ratio as you saw when you brought the slug into AE.
    Just make a 1920×1080 sequence in FCP and set the Pixel Aspect Ratio to square instead of leaving it at the 1440x1080HD preset.
    Marco Salsiccia
    Engineer of Insurrection
    Digital Anarchy
  • Mark Wilkinson
    February 9, 2007 at 11:21 pm
    thats great. thanks for the info. im buidling away…..
  • Mark Wilkinson
    February 9, 2007 at 11:24 pm
    one other twist. i exported a slug from FCP using the preset there and it is 25FPS. the preset in AE is 24 FPS. what gives ?
