Activity Forums Web Design (WordPress, Joomla, etc.) fireworks table to dreamweaver
  • Kelly Johnson
    October 20, 2007 at 4:18 pm
    Just layout the contents of the table, just the table, put your slices over each “cell’ and export.
    The resulting html table will be there. Depending of course what version of Fireworks you’re using and whether you choose to use CSS instead of html tables.
    But, just look at the table as an entire webpage, build it, slice it, export it and you can then copy and paste just the
    through to the
    tags.
