Activity Forums Apple Final Cut Pro Legacy firewire weirdness
  • firewire weirdness
    Posted by Mike Hennessey on May 12, 2005 at 4:01 pm
    I have a G4 with two Lacie firewire(400) drives and a Canopus advc-100 all connected with a firewire hub. I just hooked up my DSR-45 and every time I power up the deck I loose the firewire drives. I tried a bunch of different fixes including removing the hub and daisy chaining. This doesn’t seem to be a final cut problem. If I boot up the Mac with the dsr-45 powered on I cant see the drives. If I then power off the deck the drives magically appear. Any help would be much appreciated.
    Mike Hennessey replied 21 years, 4 months ago 2 Members · 6 Replies
  • Chris Poisson
    May 12, 2005 at 4:19 pm
    Mike,
    The Canopus box is the likely culpret. When I had one hooked up I could not control my DSR11. So I enabled EE in that deck and got rid of the Canopus altogether. Now I can capture from analog sources looped through the Sony, including Beta, VHS and DVDs. It all works great.
  • Mike Hennessey
    May 12, 2005 at 6:09 pm
    Nope, but it sounded like it would work. I’m going to try to take the canipus and the hub and see if that does it.
  • Mike Hennessey
    May 12, 2005 at 6:19 pm
    It’s doing the same thing and all I have hooked up is 2 firewire drives daisy chained going in to one port and the dsr-45 in the other. I’m about ready to hit ebay and look for a nice 3/4 online system.
  • Chris Poisson
    May 12, 2005 at 6:45 pm
    Hey Mike,
    Maybe you should try another FW bus, Lacie makes a pretty cheap card with 3 outlets on it.
  • Mike Hennessey
    May 12, 2005 at 7:06 pm
    It just occurred to me that all of my problems happed after I did a software update. I haven’t had problems like this before so I am starting to think it might be the update. Everyone may want to stay away from the OS X 10.3.9 update! I’ll sent out a post if I can isolate this to the up date.
    Is there a dip switch or menu setting on the DSR-45 that could be messing up the computer, I couldn’t see anything obvious?
  • Mike Hennessey
    May 12, 2005 at 7:42 pm
    I found it. It was the update. Thanks for your help Chris.
