Activity Forums Sony Cameras firewire to laptop
  • firewire to laptop
    Posted by Bill Jackson on October 18, 2010 at 4:53 pm
    I purchased the camera and love the features it has, but so far have had no use for the gps feature, might be a little ahead of its time.
    I use My laptop (Dell xps 1710) with Vegas Pro 9 to capture clips for editing. The NX does not have a firewire port. Can you tell me the best way to get the clips into the laptop other than taking the card from the camera?
    Thank you for your help
    Bill Jackson – Blue Horizon LLC
    Eagle Point, Oregon
    John Lenihan replied 15 years, 11 months ago 2 Members · 1 Reply
  • John Lenihan
    October 21, 2010 at 4:31 am
    You can use the usb cable from the camera to your pc.
    Just connect the wire. Then the memory cards show up on your pc. You can either copy the files over to your pc, or use the sony software utility to import them. The advantage of the cmu as it is called, is to reconnect segments that were split due only to the file size limit.
    John
    John Lenihan
    LeniCam Video Productions
    https://www.lenicam.com
