Activity Forums Panasonic Cameras firewire tape backup hack?
  • Noah Kadner
    March 17, 2006 at 7:03 pm
    Depends on your definition of viable. With the much smaller track pitch of DV and it’s not being designed originally for this application I suspect error rates and data loss will be much higher than with DLT or LTO archives.
    Noah
  • Barry Green
    March 18, 2006 at 1:51 am
    It’s interesting technology from a programmer’s perspective, but as a practical system? No way. DV tape is for video, and the hardware has built-in error correction if there’s a fault. Well, that error correction may help mask errors in video data, but it’d be disastrous in data data.
    The only prayer you’d have of making a successful backup would be to back up twice on the same tape. That drops your effective data size to around six GB per tape. Which would you rather do: spend an hour to back up 6GB of data on a $5 tape, or spend 10 minutes backup up 4.7GB of data on a 50-cent DVD-R? No matter how you slice it, backing up to DV tape is extremely expensive and slow and inherently unreliable, because the deck was never designed for that job.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
