Activity Forums Panasonic Cameras Firewire -> P2 Card Adapter and DVCPRO 1080p preview
  • Firewire -> P2 Card Adapter and DVCPRO 1080p preview
    Posted by Joerg on January 8, 2007 at 3:01 pm
    Hi there,
    Currently we copy the P2 cards with my G4 Powerbook on external bus powered harddrives while shooting on set.
    As I would like the use the Set Computer as field monitor as well, using Scopebox or a similar product and the G4 is definetly too slow for 1080p preview via firewire I am considering an upgrade to an Intel Macbook or Pro.
    But I still would want to be able to copy P2 cards with the same computer. While there is already a solution to use P2 cards via adater on the Macbook Pro Express Cars Slot, I was wondering, if there is a solution to Import P2 Cards via Firewire. This way we could use a basic Macbook on Set and save around 1000$.
    Any ideas anyone?
    Joerg
    Shane Ross replied 19 years, 7 months ago 6 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    January 8, 2007 at 3:34 pm
    For what it’s worth, it isn’t the computers speed that is the determining factor here, it is the firewire drive. Bus powered drives run at 5400RPM, enough for DV but not for DVCPRO HD. Connecting that drive to a MacBook Pro will not make it able to play back 1080i footage.
    Shane
    FCP Preferences set to UNCONTROLLED ADVICE
    Littlefrog Post
    http://www.lfhd.net
  • Joerg
    January 8, 2007 at 4:01 pm
    thanks shane,
    this may be right for capturing, but I am only talking about recording on P2 cards, while previewing (for focus and exposure) on the Computer with Scopebox. HDD performance should not be an issue there. It’s more a CPU thing i guess.
    The bus powered drives are only used for copying the data from the P2 cards.
    regards,
    joerg
  • Shane Ross
    January 8, 2007 at 4:19 pm
    Pardon my misunderstanding.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    January 8, 2007 at 4:55 pm
    [joerg] “I was wondering, if there is a solution to Import P2 Cards via Firewire.”
    Yes, but it ain’t cheap:
    https://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=72037&surfModel=AJ-PCD20
    Jeremy
  • Joerg
    January 8, 2007 at 5:27 pm
    Thanks Jeremy,
    I was hoping there is a single pcmcia card adapter solution in the 100$ range.
    Guess I have to wait a bit for that.
    For the moment it locks like the Macbook Pro and the Duel systems ExpressCard->PCMCIA Adapter ist the best solution.
    Joerg
  • Jeremy Garchow
    January 8, 2007 at 5:39 pm
    [joerg] “I was hoping there is a single pcmcia card adapter solution in the 100$ range.”
    You and everyone else, man.
    Concerning the MacBook vs MacBook Pro, your money is best spent on the MBPro as you can then use it to edit/preview as well in FCP.
    Jeremy
  • Barry Green
    January 8, 2007 at 6:03 pm
    [Shane Ross] “Bus powered drives run at 5400RPM, enough for DV but not for DVCPRO HD. Connecting that drive to a MacBook Pro will not make it able to play back 1080i footage.”
    5400RPM is fast enough to play back 1080, it may depend on other factors but on my Core 2 Duo 2.00GHz laptop with 5400 RPM SATA drive it plays back 1080/60i, 1080/24p, and 1080/30p in full-screen without a hitch.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Shane Ross
    January 8, 2007 at 7:45 pm
    [Barry Green] “5400RPM is fast enough to play back 1080, it may depend on other factors but on my Core 2 Duo 2.00GHz laptop with 5400 RPM SATA drive it plays back 1080/60i, 1080/24p, and 1080/30p in full-screen without a hitch.”
    I stand corrected.
    Now is there any other way I can get my foot into my mouth?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    January 8, 2007 at 8:14 pm
    [Shane Ross] “Now is there any other way I can get my foot into my mouth?”
    Yes!!!………Yoga!
  • Arnie Schlissel
    January 9, 2007 at 3:12 am
    Run for president?
    (insert evil laugh here)
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
