Activity Forums VEGAS Pro Firewire Dropouts
  • Firewire Dropouts
    Posted by Rich Stahle on August 29, 2005 at 10:10 pm
    ok I’ve been using Firewire drives literally for years now, rendering stuff to them using Vegas.
    Now it seems I can’t render anything without the drive dropping on me.
    Using Vegas 6 and in some cases, VEgas 5 – things chug along then anytime 10-30 minutes in – the drive drops and that is that.
    Any clues why? THIS IS ANNOYING AS HELL!!!!
    I touch NOTHING, I do a power cycle of the computer & drives – everything comes back up so don’t tell me it’s the cables!
    Gary Kleiner replied 21 years ago 4 Members · 3 Replies
  • Greg Lewolt
    August 30, 2005 at 2:10 am
    This may not be of any help , but
    I recenty struggled with my son’s computer that was freezing at certian points. tried everything.
    Last week I built a new internet computer and found I needed a graphic card, so I pulled the one out of my son’s computer. Everything worked fine until i went to windows update and downloaded an update to the graphics card.
    Same crashes started happening! I used system restore to back up a day and then did not update the graphic card, computer runs perfectly now!
    Beware of windows update!
  • Donatello
    August 30, 2005 at 5:21 am
    is this ONE 1394 drive or all?
    i have one 1394/USB drive that drops after about 30 min when i use the 1394 connection .. however when i connect thru USB no problem .. i have 3 other cases by same manufacturer with no 1394 problems .. i called case manufacturer and they are replacing it …
  • Gary Kleiner
    August 30, 2005 at 7:21 am
    I recently changed most of my external drive hookups from firewire to USB 2 (which is actually a bit faster throughput) and am much happier with the connectivity now.
    Gary
