Activity Forums Apple Final Cut Pro Legacy FireWire Drive: She’s DEAD Jim.
  • FireWire Drive: She’s DEAD Jim.
    Posted by Kevin Monahan on August 23, 2006 at 8:20 pm
    Howdy There,
    I’ve been having some trouble with a certain FireWire drive that has trouble unmounting. I have been able to restore it in the past by running Disk Warrior on the main HD – then the FireWire HD pops up on the desktop. Kind of strange, but it’s been working.
    Today, the same thing happened. It would not mount.
    As usual, I ran Disk Warrior, yet I cannot seem to bring the disk back to life as I usually can. I really don’t want to blow away 100 GB of stock footage I painfully loaded from DVD if possible.
    Any ideas? Should I go for Tech Tool Pro? I should probably buy it anyway. 🙁
    This is why I don’t like FireWire drives, they eventually screw ya no matter how careful they are. And believe me, I’m A.R.. with my portable drives.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
    Kevin Monahan replied 20 years ago 7 Members · 12 Replies
  • 12 Replies
  • Ed Dooley
    August 23, 2006 at 8:31 pm
    Kevin,
    TechToolPro is useful, and it may help you. But it may not be the problem. I’ve had the same thing happen with
    a couple of FW drives; in one case the drive enclosure is a combo FW800/USB2 case. When it wouldn’t mount as FW800,
    I could get it to mount as USB2. If I did that and then ejected it, it would then mount as FW800. It was the board inside
    the enclosure at fault. With the other case I could wiggle the FW cable. It would mount when it was twisted in a certain way. If
    I stood the case up on end with pressure maintained on the cable, it would stay mounted. In both cases the drives themselves were fine.
    If you can get your hands on another case you can see if that’s it.
    HTH,
    Ed
  • Steven Gonzales
    August 23, 2006 at 8:54 pm
    If you’re not under warranty, I’d pull the drive out to see if it’s the drive or the firewire bridge (or maybe power supply) that’s dead.
    Is it a single drive or a raided pair? I’m not sure how to test the raided pair, but a single is rather easy to check.
    I have a wiebetech firewire TrayDock and bought a drive tray for IDE and a drive tray for SATA, so I can get at either type of bare drive.
    An sata you could pop inside the G5. Perhaps you have an old G4 machine to slap the drive into if its IDE, to see if it shows up.
  • Kevin Monahan
    August 23, 2006 at 10:07 pm
    JIm,
    How did you know I was calling you when I said, “She’s DEAD Jim.”
    Hilarious!
    Anyway, YES, I just happen to have a spare USB2 enclosure. I’ll pop the drive into that and see “what up”.
    Steven,
    Thanks for the reply.
    [Steven Gonzales] “If you’re not under warranty, I’d pull the drive out to see if it’s the drive or the firewire bridge (or maybe power supply) that’s dead.
    An sata you could pop inside the G5. Perhaps you have an old G4 machine to slap the drive into if its IDE, to see if it shows up.”
    I’m fairly certain that the drive is fine, but the header file to make it mount seems to constantly get corrupted. So something is rotten in Denmark.
    This is a single Hitachi Deskstar 120 GB in a fairly cheapo enclosure that’s work OK for a long time. It ABSOLUTELY could be the case or something rotten in Denmark – like an OS thing.
    Unfortunately, all I have is TiBooks today.
    Thanks for your words of advice. I’ll post back later with a solution.
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
  • Peter Wiggins
    August 23, 2006 at 11:33 pm
    Kevin
    Have you checked your Dilithium Crystals? 🙂
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Dan Riley
    August 24, 2006 at 2:07 am
    You’ve probably already tried this, but if one of my firewire drives
    doesn’t mount at startup, I open disk utility, highlight the drive and
    hit the mount button. Usually works.
    I only use Firewire drives for backup and they are very useful for
    putting an entire offline and online project on one 500 or 750 gig drive.
    Dan
  • Arnie Schlissel
    August 24, 2006 at 4:16 am
    [Peter Wiggins] “Have you checked your Dilithium Crystals? :)”
    I think Kevin just needs to reverse polarity…
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
  • Debe
    August 24, 2006 at 4:18 am
    [Arniepix] “I think Kevin just needs to reverse polarity…”
    …of the flux capacitor or the neutron flow?
    debe
  • Arnie Schlissel
    August 24, 2006 at 4:24 am
    [debe] “…of the flux capacitor or the neutron flow?”
    I believe he has to reverse polarity on the flux capacitor so that he can use it to reverse the polarity of the neutron flow. Crap! These damn tribbles are eating all of my quadro-triticalli!
    Arnie
  • Kevin Monahan
    August 24, 2006 at 5:03 pm
    That’s the trouble with Tribbles! Now where’s that USB enclosure?
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
  • Debe
    August 24, 2006 at 5:53 pm
    [Kevin Monahan] “Now where’s that USB enclosure?”
    Didja already pack it, Kevin?
    debe
