Activity Forums Apple OS X Firewire Drive Recommendations
  • Firewire Drive Recommendations
    Posted by Les Kaye on November 23, 2006 at 7:47 pm
    PLAN on getting a MacBook Pro shortly. Per the recommendations from David Weiss Roth and others on the FCP forum, I’ll use a SATA setup for any serious video editing when (and if) that time come. My question, I’d like to also create a music server for home use, as well as use FCP on the MBP for personal family projects. Would I be okay with a Firewire drive? Any recommendations? I’ll probably be getting it via the Apple Store – unless there are better recommendations here too.
    Much thanks,
    -Les
    Jeff Carpenter replied 19 years, 10 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    November 24, 2006 at 5:34 am
    Make sure it has firewire800 and use that.
    The G-Tech G-Drive is probably a nice safe bet. Their G-RAID gives a little more speed for a little higher price. You should compare those 2 products.
    Otherwise, any firewire 800 drive will probably do fine. LaCie is popular. Western Digital too.
