Activity Forums Apple Final Cut Pro Legacy firewire drive is acting up
  • firewire drive is acting up
    Posted by Scottyp on July 7, 2005 at 10:29 pm
    Just have a firewire drive question. Got a 2 year old EZquest Firewire drive that is making strange noises. Ok when first start up. then spins up hard, then down. Then a constant buzz. Any way to check what’s going on? is this at all normal every once in a while?
    thanks
    scott
    Kevin Monahan replied 21 years, 2 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    July 7, 2005 at 11:49 pm
    Sounds to me like it’s getting ready to go south… I’d back it up right away… That said, is it a fan making the noise, or the drive mechanism itself? If the drive mechanism, backup now… it may die shortly… This isn’t normal.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jeremy Garchow
    July 8, 2005 at 3:43 am
    I worked at ajoint that had a few of the ez quest cobra drives (big silver plastic thing, right?). It always made strange noises at start up and always worked like a champ, even though it sounds like a garbage disposal.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Scottyp
    July 8, 2005 at 4:58 pm
    it’s very erratic. can’t tell if its only the fan. just backed up, and now looking for new firewired drive. Should I make sure to get Firewire 800. My new powerbook has a port, but my desktop does not. Are people using it for FCP HD, or does it not make a difference?
    thanks
    scott
  • Kevin Monahan
    July 8, 2005 at 11:28 pm
    If you’re gonna get a FW 800 drive, get a PCMCIA card to go along with your PowerBook and a PCI card to go with the Tower, That way the data will be flowing on a separate bus than your DV deck.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
