Activity › Forums › Apple Final Cut Pro Legacy › Firewire capture
  • Firewire capture
    Posted by Bob Hanson on September 13, 2007 at 4:56 pm
    I’m using Studio 2 and a Sony DSR-1500. Problems with going into the capture mode, slow to initialize, slow to respond, sometimes a reboot helps. Any thoughts?
    Chris Poisson replied 19 years ago 2 Members · 1 Reply
  • Chris Poisson
    September 13, 2007 at 6:00 pm
    Bob,
    Check your cables and fittings. If that doesn’t help, trash prefs. Also make sure the deck is set to DV and plugged in and on before you boot up everything else.
    Have a wonderful day.
