Activity › Forums › Avid Media Composer › Firewire camera not working
Posted by Ron on February 23, 2006 at 1:37 amFirewire camera sony dcr- trv103 not working. Any work arounds it is not under deck configurations.
ThanksRon replied 20 years, 7 months ago 2 Members · 4 Replies -
Ron
February 23, 2006 at 9:26 amMy current camera is not on the Avid xpress dv device list need to get something cheap any recommendations just view avid via firewire to NTSC monitor
thanks
Ron -
Themis
February 23, 2006 at 6:18 pmAvid has issued a post regarding a well known problem with deck control and Xpress Pro HD. All you have to do is register the DVBuffers. Click Start and then Run. In the command line, type: regsvr32 DVBuffers.ax. If typed correctly you will get a display message “DLLRegisterServer in DVBuffers.ax succeeded”. That might solve your problem.
Themis
Ron
February 23, 2006 at 10:05 pmClick Start and then Run. In the command line, type: regsvr32 DVBuffers.ax.
Not sure about click start and run ?????
