Activity Forums Apple Final Cut Pro Legacy firewire and powerbook g4
  • firewire and powerbook g4
    Posted by Amanda Nesco on January 17, 2007 at 11:10 pm
    Hello, I am having trouble connecting my firewired to my powerbook g4 which runs on os x. When I try to capture video from final cut it say no device detected. Please help me. Thanks so much
    Amanda Nesco replied 19 years, 8 months ago 5 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    January 17, 2007 at 11:40 pm
    [Anesco] “. When I try to capture video from final cut it say no device detected. Please help me. Thanks so much”
    And that device is…..?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Amanda Nesco
    January 18, 2007 at 5:06 am
    I am tring to connect a sony DV cam with a 6pin firewire to my powerbook g4
  • Ed Dooley
    January 18, 2007 at 5:34 am
    More info! I use my PB to capture video occasionally and it works fine.
    More details, more details!
    Ed (soon to be a MBP owner)
  • Wilhelm Beck
    January 18, 2007 at 9:04 am
    I
  • Walter Biscardi
    January 18, 2007 at 11:42 am
    FCP Version? OS Version?
  • Amanda Nesco
    January 18, 2007 at 4:30 pm
    Thanks but my camara is reading the firewire, its my computer that isnt.
  • Coach
    January 18, 2007 at 4:41 pm
    I would guess it might be a problem with QT. This is pretty common post here. I would think you are using a small mini dv camera as a deck. If you are try this a possible fix.
    Coach
    https://docs.info.apple.com/article.html?artnum=301852
  • Amanda Nesco
    January 19, 2007 at 4:10 pm
    Thanks for the help, I tried this and it’s still not working. My comp is recognizing the firewire bus but final cut is not recognizing the FW. I think I’m going 2 try it on a different make to see if maybe it’s the firewire itself that is damaged…….
