Activity › Forums › Apple Final Cut Pro Legacy › firewire and audio
  • Bouncing Account needs new email address
    March 18, 2006 at 3:24 am
    Virtually all camcorders with the DV format can playback Ch. 3 & 4, but you need to switch them to that mode (likely in the MENU settings for audio).
    Likewise, FCP must be set to access Ch. 3 & 4.
    Here’s how (it is the same for PAL, but you will of course use the PAL settings):
    Final Cut Pro (menu pull-down) >
    Audio/Video Settings >
    Capture Presets >
    Click the “Duplicate…” button >
    a new “Capture Preset Editor” window will open >
    Change the “Name:” field to DV NTSC 48 kHz CH 3&4 (so you’ll be able to tell it apart from the “normal” setting.)
    Under QuickTime Audio Settings >
    Input: Second 2 Channels >
    Click “OK”
    Now, try a capture. If the audio is on CH 3&4, you’ll get it into FCP.
    Remember to put your “normal” settings back (to “First 2 Channels”) after you captured CH 3&4 tracks.
