Activity Forums Panasonic Cameras Firewire adapter for Vari
  • Firewire adapter for Vari
    Posted by Rob Mcwilliams on August 3, 2007 at 5:31 pm
    I have shoot coming up where client wants to record HD signal via firewire to his computer FCP.
    What is a good HD-SDI to Firewire adpator? I know AJA and Mirnada make them but thought I would check with you guys on which model is the right one.
    Rob Mcwilliams replied 19 years, 1 month ago 2 Members · 2 Replies
  • Michael Sacci
    August 3, 2007 at 6:31 pm
    This will down-convert your signal to DV. It would be better to use the HPX900 since it has firewire out. Or the new AJA IoHD would do the trick.
    If you can bring a Tower then all you need is a Capture card from AJA or Black Magic but I’m pretty sure you would lose timecode this way.
  • Rob Mcwilliams
    August 3, 2007 at 7:52 pm
    thanks.
    talked to Panasonic. Only real option is the 900.
