Activity › Forums › Apple Final Cut Pro Legacy › Firewire – 2 streams from one
  • Firewire – 2 streams from one
    Posted by Jim on May 16, 2007 at 9:46 pm
    I have a client who wants to record a lecture series. Each presentation will be 1.5 to 2 hrs long. They would like to record directly to hard drive, but also to back up to tape. Now I can take the FW out of the camera directly to the HD, and the Y/C & audio to an M25 deck, but has anyone been successful in splitting the FW stream to feed both a computer (MBP w/ FCP5.1.2) and the FW input to a deck?
    I know there is machine control info going down the FW stream, would that cause problem?
    I’m sure there is a wizard that has tried this. Any insight would be greatly appreciated.
    Cheers,
    Jim replied 19 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Bbalser
    May 17, 2007 at 1:12 pm
    FW is a super chatty transfer protocol. I’ve tried spliting it out to a laptop and Firestore at the same time, can’t seem to get it to work. Too much data flowing through the pipe.
  • David Bogie
    May 17, 2007 at 3:42 pm
    You would need a firewire hub. Generally, not recommended; just too many things that can go wrong. Trust tape.
    bogiesan
  • Bbalser
    May 17, 2007 at 4:22 pm
    A hub won’t work because Firewire is more like a network protocol and is very chatty. The hub will be flooded with chatter and data and send/recieve it from all connected devices. That’s the technical theory. BUT I am borrowing a FW hub today to test it out. I have a feeling I can make it work. Will report back.
    – Apple Certified Trainer
    – Tutorials at http://www.bbalser.com
    – South Louisiana FCP Users Group
    – NOVAC Digital Filmmakers Institute
    – Event DV magazine
  • Russell Lasson
    May 17, 2007 at 4:35 pm
    Take a look a this:
    https://www.lairdtelemedia.com/Product.asp?cat=ROUTERS&subcat=&prodClass=FIREDA&search=0&off=0&baseItem=LTM%2DDVDA5P
    It might be what you’re looking for. (It’s still record to tape as a backup.)
    -Russ
  • Rennie Klymyk
    May 17, 2007 at 9:52 pm
    https://www.kramerelectronics.com/indexes/item.asp?desc=365
    Here is another one that works fine for this. I have one and it does it and more. Down load the manual for more info.
    “everything is broken”
  • Rennie Klymyk
    May 17, 2007 at 10:15 pm
    Here’a an active link
    Oops, didn’t mean to cut in front of your post Russ, this is the same thing but I have one and can confirm it will do it. I just use it as a firewire wire router but you can split 1 source to 5 outs with this unit.
    more info.
  • Jim
    May 19, 2007 at 2:23 am
    Thanks for the info. I’ll check out the Kramer.
    All the best.
