Activity › Forums › Adobe Premiere Pro › Firewie to USB Cable
Posted by Alvin Lowery on November 25, 2012 at 7:53 pmAnyone using a firewire to usb cable to capture video with the new computers that do not have a firewire port?
Ann Bens replied 13 years, 10 months ago 7 Members · 6 Replies -
Angelo Lorenzo
November 25, 2012 at 10:01 pmI don’t know anyone personally, but I would be aware of two things:
1. Firewire supplies 12v while USB supplies 5v. This probably won’t be an issue with cameras as they’ll use battery power but I wouldn’t try plugging in any port-powered firewire 400 hard drives.
2. It would come down to a driver issue. If your cable doesn’t come with software, I would doubt that it works. Firewire is the cable used for the IEEE 1394 interface which has instructions that multimedia equipment like video cameras use to communicate with your computer.
I’ve seen a few “conversion” cables on Amazon and the like but they all rate very poorly so YMMV.
https://forum.videohelp.com/threads/343433-Capturing-DV-camcorder-to-laptop-w-o-firewire-port is worth looking at.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks -
Dave Morrison
November 26, 2012 at 2:57 amNope, can’t do it. They are two completely different data transport protocols.
Anthony Burokas
November 26, 2012 at 2:39 pmYea. Different protocols, different drivers, etc.
You can’t have a USB interface emulated over Firewire and if it were even possible, the demand is so low as to never make it happen.Anthony Burokas ~ https://IEBA.com
Shane Ross
November 26, 2012 at 4:33 pmThere are FireWire to Thunderbolt adapters. If you are talking about Mac computers.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Mike Smith
November 26, 2012 at 5:54 pmYou could go for an expansion card like (there are lots of others)
according to what expansion potential your machine has.https://www.amazon.co.uk/Startech-com-ExpressCard-FireWire-Laptop-Adapter/dp/B003N3J354
or https://accessories.euro.dell.com/sna/productdetail.aspx?c=uk&l=en&s=dhs&cs=ukdhs1&sku=500-10056&~ck=baynoteSearch&baynote_bnrank=0&baynote_irrank=0&ST=Cables%20-%20I/O,LPB&dgc=ST&cid=41141&lid=1069630&acd=239715600820560 -
Ann Bens
November 27, 2012 at 10:45 amIf you are talking PC waste of money, does not work properly.
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional
