Activity Forums Panasonic Cameras Firestore to P2 problems ~
  • Firestore to P2 problems ~
    Posted by Arty Gold on April 13, 2009 at 8:49 pm
    I’ve tried looking for any help on this
    we use the Firestore fs-100
    we also have a P2 card we use for smaller things
    well during an event the usual Firestore crap happened where files become un-readable
    however i noticed that we could play and watch the file thru the firestore into the camera
    i called firestore and they said i could copy the bad files to the p2
    did that
    now final cut pro won’t log and transfer the footage probably….
    like i get video no audio
    choppy footage etc
    does anyone know the process for this case ?/
    Michael Sacci replied 17 years, 5 months ago 2 Members · 3 Replies
  • Michael Sacci
    April 13, 2009 at 11:42 pm
    What are all your settings? Sounds like a mismatch between the Firestore’s footage and the camera’s settings.
  • Arty Gold
    April 14, 2009 at 12:16 am
    it could be
    basically i took my firestore and i connected it to the camera
    pressed play record on the camera
    and than play on the firestore
    which recorded it to my p2 card…
    when i play back the p2 card it plays fine
    to get it into fcp…well that’s another story
    it’s coming up in log and transfer
    but it will also play thru in log and capture
    problem with that is it shuts off with timebreak errors
  • Michael Sacci
    April 14, 2009 at 3:46 am
    What was your shooting mode when you recorded to the Firestore?
    How was the Firestore setup?
    How is the Camera setup when you try to record back to the P2?
    These things should not be assumed to be correct. [Arty Gold] “problem with that is it shuts off with timebreak errors “
    What is IT, the Firestore? FCP capture?
