Activity Forums Apple Final Cut Pro Legacy Firestore problem
  • Firestore problem
    Posted by Ron Craig on March 21, 2009 at 10:41 pm
    Any Firestore users out there? I have had great success using a Firestore FS100 to record DVCPRO-HD video from an HDX-900 and import it into Final Cut Pro. (We record to tape sumultaneously.)
    Recently, when making a backup copy of the Firestore data before Log & Transfer to FCP, the process has failed. This has happened twice: With the FS100 and an external firewire drive connected to a Mac, the copying process fails at some point and both the FS100 and the external firewire drive get dismounted from the computer. I get this error message: “The operation cannot be completed because you do not have sufficient privileges for some of the items.”
    It becomes a pain then to get the data into FCP. Has anyone here seen this? Any suggestions?
    — Ron
    Torrey Loomis replied 17 years, 5 months ago 2 Members · 1 Reply
  • Torrey Loomis
    March 25, 2009 at 10:53 pm
    Ron,
    I’ve seen weird things happen on a few occasions like this:
    1. The destination drive isn’t formatted for Mac OS X Extended, but rather MS-DOS.
    2. The destination drive is going bad.
    3. Or, you have them plugged into the Mac via a chain…i.e. your Firestore plugged into your drive plugged into your Mac. In this case, if one drive’s ports went south it could take the other one with it.
    Torrey
    Torrey Loomis
    President & CEO – Silverado Systems, Inc.
    Outfitter to the World’s Foremost Apple Professionals
    2600 East Bidwell Street, Suite 280
    Folsom, CA 95630
    (916) 760-0032 • FAX (916) 404-5258
    torrey@silverado.cc
    https://www.Silverado.cc
    Check out our StudioBuilder blog at https://silveradosys.blogspot.com
